asrock70
Full Member level 4
I try to construct a LCR meter, as I have DDS source that can +-5mV to +-1V, frequency of 100Hz to 1MHz. I would say quite a decent quality signal 2 fixed LPF 7th + active adaptive LPF + three attenuators. As otput amplifier is use AD8021.
Now I deal with current measurements after passing through the measured object.
My first thought was to use an amplifier as the voltage current converter, but I ran into a problem in the upper range. Here I assume limit frequency to 100kHz, the maximum measured impedance 100M.
See Figure, V1,U1,R1 is the source signal (in real DDS modul), R2 is DUT, R3, U2 is U to I converter with AD8021.
It works satisfactorily for larger currents, a low impedance measured DUT,
It works satisfactorily for larger currents, a small DUT impedance measured at high impedance begins to have a big impact a small input resistance AD8021 (10M only) and current to or from input AD8021.
Any idea how to solve it?
