[SOLVED] AC analysis (frequency response) for switch capacitor circui
A
ahmadagha23
Newbie level 1
Hi;
I want to measure frequency response and phase margin of a switch capacitor circuit by simulation. I think it is impossible with HSPICE. Do you know any software or method for doing that?
regards
Re: AC analysis (frequency response) for switch capacitor ci
Of course it's possible - with any SPICE simulator. Just keep the SC circuit in Hold mode and run a std AC analysis!
what do you mean in hold mode? how can i do that?
I think it is not possible to do ac analysis because there is not any defined(fixed) operation point for the SC circuit. I listened that spectreRF and swicap are softwares for doing that. but as i understood they have not windows version. is it true?
regards
ahmadagha23 said:
Hi;
regards
Yes, it is possible with each SPICE based simulator (and with some other specific programs like SPECTRE...).
For this purpose you have to transform the time discrete S/C network into a time continuous equivalent. There are two approaches to do this which are decribed elsewhere (books, journal contributions, application notes).
As far as I remember this subject has been discussed already in this forum.
Try to search using appropriate keywords or use "similar topics" at the bottom of this page.
I am not sure about Hspice.but there is pss and pac analysis in spectreRF which can do ac analysis for descete systems
-rampat
