Absolute value voltmeter error
lats
Full Member level 4
Full Member level 4
Dear all
m designing a voltmeter circuit which gives the absolute value of the input voltage (i.e , if the polarity at the input voltage side changes the output will be the same voltage with positive value).
the problem is the circuit works well with all the voltages (range -2V to +2 v) but when i give 0 volt at the input the output should give me 0 volt but m getting 146 mV output. the opamp i want to use is LM324 only .
Please help me out. how to correct this ?
This is offset voltage of your opamp.
Use offset null pin to make it zero if your opamp has this pin or use a opamp with this feature
I can use only LM324.
Because of cost factor and is compulsory requirement in this project
I dont think 146mv is a issue in a low cost design
There are many factors which contribute in such situations like offset voltage of a amplifier(it is output voltage that is present even at no input),noise effects and many more.
so what is the solution m asking.....???????
Added after 3 minutes:
thanks anyway i got the solution
