Only current reference !
If lines is long that voltage reference is very inaccurate.
If your output buffer is placed 10mm away from the pads, I think 30mV deviation is good enough. Have you tried to place the buffer as closed to pad as possible and make the reference as short as possible and the 30mV deviation gone? I doubt this is due to mismatch and finite gain of the opamp more than the opamp reference inaccuracy.opamp array are used to buffer output signal, the test results shows the output pins deviation is very large, more than 30mv.
