liujingshu
Junior Member level 1
verilog compiler explanation
Hi,all
Our company assign me to stimulate(use Modelsim) and compile(use Design compiler) a code. The stimulation is not very difficult, but compiled is not easy, for it is my first compile job. I can say the code is not very good, for most of module can pass the gate netlist stimulation(without timing information, sdf file) but can not pass the timing stimulation(gate netlist and sdf file). Up to now, my only method is change the code. Fortunately, I correct most of them, but one of them is much bigger, it is not very easy to change. Does have and other method to deal with this problem? May be to set the constraint, but I don't how. May be somebody can give some tips. Thanks very much!!
Hi,all
