about total harmonic distortion
wjlzhx
Member level 5
Member level 5
spectre foureval
hi
I HAVE A PROBLEM NEW
HOW TO SIMUALTE HARMONIC DISTORTION IN SPECTRE
PLEASE HELP ME
THANKS ADVANCE
spectre distortion
wjlzhx said:
hi
PLEASE HELP ME
THANKS ADVANCE
Check it out here.
harmonic distortion
thanks lodeyh
but i still have the problem .
in calculator i find two function
one is foureval ,it has four param ,some param i do not know ,how can i fill in the param (from ,to and by)
another is harmonic .it has two param one is signal ,the other is harmonic number .
i fill the harmonic number is 10.
when i click the plot button ,i got wrong
how can i do
please help me
total harmonic distortion calculator
wjlzhx said:
hi
PLEASE HELP ME
THANKS ADVANCE
Use Electronics Workbench Multisim.
total harmonic distortion help
Electronics Workbench Multisim ??
is it a software????
IN hspice I can get THD ,BUT in spectre i can not,
does somebody use spectre to calculator THD
total harmonic distorsion
An easy to determine the THD/SFDR or whatever, is to make use of the component fourier/fourier2ch. These two components are located in analogLib and they are specific to the cadence simulator spectre. If you place them in a schematic and run a transient anaysis, you will get the fourier coefficients of the corresponding waveform. And you will also get a summary of the HD2, HD3, THD and etc.
    wjlzhx
analoglib fourier
thanks for you help ,it help we a lot.
now i put the component fourier in my schematic ,and i get the thd in spectre.
but i also puzzle the component fourier2ch ,how to use it.
total harmonic distortion explained
I haven't tried out the component fourier2ch. There is more information in the cadence document. Try to use
spectre -h fourier
to get the detailed description.
There is also a very good reference in the website of Cadence. It may help you to understand more.
    wjlzhx
