The INL and DNL are parameters that characterize the deviation on the code transition voltages of the ADCs. On the laboratory this is measured using the histogram method, which is a statistical method. However this requires a large number of samples – to use this method your simulation would take a LOT of time.
So, I guess that the best option is to put a slow ramp at the input and determine the input voltage where each code transition occurs. But note two things:
1. The ramp must be really slow, if you want to have a decent measurement accuracy. For example, if you want to have a resolution of 0.1 LSB in your measurements, the input voltage must take 10 clk cycles to increase one LSB. For a 10-bit converter you need a simulation with 10*1024=10240 clk cycles, which still results in a rather large simulation.
2. If you want to have realistic results, your simulation must include device mismatches; otherwise you can get almost ideal results in the simulation and bad results in silicon.
An option usually used is to build a model of the ADC (usually in MATLAB or C), which is much faster to evaluate. However, to do this you must model the non-idealities of each block of the ADC. You MUST have a very deep insight on your ADC’s architecture and on each blocks’ limitations.
