guo-hai
Junior Member level 1
Hey guys,
I know that adding a dielectric in a two plate can add the charge in the plate, so it can add the capacitance.
But I have a problem, When we place the dielectric in the E field, there is a dipole moment which produce internal E ( E polarization ) that opposed the E field, so the E field is reduced.
My question is How can E field is reduced while the charge in the plate is increased? Isn't it a contradiction?
I found this answer from this web **broken link removed**
"A decreasing E-field would cause the potential difference to decrease--if it could. But it can't here, so the battery does what it can to make the E-field correspond with the amount of potential difference. How do you adjust the charge to increase the E-field? You have to increase it. So the battery pumps more charge to the plates. The charge increases and the energy increases. "
I understand it, but I'm not still satisfied with the answer, cant anyone tell me?
Thank YOu
Thank YOu
