About Sample & Hold circuit
gagagagazi
Newbie
Newbie level 3
I am trying to study a Sample&Hold Citcuit, as shown in Fig.1, Vosc- and Vosc+ are the signals (opposite signals) that control J3~J6 generated by the pluse generator respectively, and the in Fig.2, my understanding It is when J4 and J5 are closed at the same time, the voltage of point VM+ should be the input voltage V+, but I don't know why, when I simulated in LTspice, the voltage of VM+ is almost the same as the signal Vosc- (as shown on the left side of Fig.1), I don't know what caused this, is there any solution? Thank you so much.
Fig.1
Fig.2
Switch phasing must ensure there is no overlap which
would ohmically mess up the transfers-of-charge.
4nF is pretty chubby. Maybe FET on resistance makes
a time constant that is lower than your sampling pulse
pulse width and so incapable of a clean single pulse
sample. Zoom in on a single clock cycle and assess
the sampling settling, and the hold droop.
But how you expect to control -15V signal with FETs
operating between Gnd and positive supply, I do not
see offhand. Maybe you should back up a few steps
and figure out the regions where those FETs have
actual, proper authority / operation - including that the
controlling sources are doing the right thing at those
various bias-points.
