jiaming_lee
Junior Member level 2
I am designing CT sigma-delta. and using RZ (return to zero) feedback. So, is RZ really return to zero (common mode voltage), which is in regardless of the input signal, during half of the clock, or it is return to the voltage, which equals the input voltage at that time, so, half of the clock, the integrator does not do the integration?
Since I found that if return to exact zero, with the input voltage swing, the integrator would do the wrong interation.
