About random data generation using verilog language
sycolegend
Newbie level 5
Newbie level 5
Hi all,
My design needs a huge number of random data. I have used $random to generate random data. But these data is all the same when I restart the simulation. Can any body telll me how to generate pure random data in verilog.
Thx in advance
If you are using Cadence, there is a cell called "rand_bit_stream" inside the library name "ahdlLib". You can use that to generate random data.
If you are not talking about Cadence, maybe the follow code might help you
integer iseed;
bit = abs($random(iseed)) & 1;
hope this helps!
    sycolegend
If you want different seed need to be used, please try this.
reg [31:0] data ;
initial
data = $random();
<your loop>
data = $random(data) ;
this logic will change your seed for each iteration.
regards,
sakthi.
    sycolegend
