About pattern and gain of antenna
llololl
Junior Member level 3
Thailand
I have a Big problem about pattern and gain of antenna in thesis.
So,I designed ring antenna like "CPW-fed crescent patch antenna for UWB
applications by M.-E. Chen and J.-H. Wang".
But My pattern and gain are not cover in UWB.
Who has any ideas for be a good advise to develop my antenna.
1.design and improve pattern
2.increase gain for cover all frequency in UWB.
please help me
thanks & Regards,
hi llololl!!
The uwb application spetrum is from 3.1 to 10.6GHz. At your simulated results of antenna gains, I could assumed in the higher band(7-10.6GHz) has no resonate mode exist. You can adds a short current path to generate a mode. Therefore, a wideband operating can be obtained.
    llololl
Thanks for idea.
how do it in IE3D?
Hi, llololl:
It is tought to get UWB for impedance. It is even tougher to get UWB performance for patterns. For the particular antenna, the gain at (theta,phi)=(0,0) is ok below 7 GHz. There is a dip at 9 GHz at (0,0). The peak of the gain at 9 GHz is at other angles.
Best regards,
    llololl
