about mini project related to HDL
praghavendrareddy
mini projects based on hdl
hi
i want mini project with details related to HDL language i.e either in VHDL or VERILOG with details.
pls anyone help me its urgent
try building a stopwatch .. or a digital watch ..
you can also build a calculator ..
pls give an clear cut idea or information
Added after 3 minutes:
chviswanadh said:
Please clarify what u want. Do u need a material related to a project or material on VHDL and Verilog
thx for reply,yes i need a material related to a cetain project wat u have
say you decided to build a calculator :
1- you will need to build an adder, multiplier, subtractor, divisor .. etc.
2- you will need to run one of these operations once one enables it (by pushing the button).
3- you will need to have couple of registers to save the operands of any operation and the results.
4- you will need to write a 7-segment or LCD driver.
i guess this can be the simpliest start in HDL. Try to look at an existing calculator and take it as a reference .. don't implement the fancy stuff.
U can design a 4 bit Arithmatic Logic unit where u need to implement the logical operations and the arithmatic operations. U can even extend this by implementing floating pint operations also,it is upto u. I will try to find some material if ur interested in this.
the mini project can be designed in Altera Quartus II or EDWinXP etc
Also, traffic light can be good project
hello everyone:
i need a code for calculator in verilog hdl.
plz its urgent.
do it by your self its easy
u try opencore site u will get some projects. tryout those projects
