lhlbluesky
Banned
in layout of fully differential opamp, an offset often exists. in tt corner, it may be 20uV, but in ss or ff corner, it may be 60uV or -40uV, that is, for different corner, the offset can be different also. The same case for different temperature also.
how to understand this? and how to minimize the layout offset of a fully differential opamp?
besides, for a 2X circuit, vout ( = vout+ - vout-) = 2 * (vin+ - vin-), but if the input vltage is small enough, such as 10mV or less, to reach 10 bit or more resolution, the offset must be less than 10uV. in tt corner, the offset may be less than 10uV, but for other corner (ss, ff, sf, fs), the offset may be 100uV or more, and the offset may be a negative value, how to deal with this problem to reach 10 bit resolution in all corner for a small enough input?
i'm really confused about this probelm, pls help me, thanks all.
