About Layout and fabrication
preet
Full Member level 1
hello all,
Can we define the parameter like thickness of oxide, doping concentration of transistor etc while designing layout.
regards
preet
I'm not really sure what you're asking. Anyway if I understand well, yes you can define the thickness of oxyde and different concentration and many other things for layout.
It's just take several CAD layer, good programming and understanding of the tekno.
No. Just use the design rule and layout it. no the phy parameter
Oxide thickness is not controllable in the real sense of the word. It changes with temperature and fabrication conditions. It varies from transistor to transistor depending on the doping profile during the fabrication.
There is a typical, slow and a fast corner for it. A good design should take this process variability into account. VCOs for instance, can be off by as much as 2x in frequency as a result of such variation.
During layout, you just use the DRC rules as pointed out right above this post.
