lhlbluesky
Banned
kt/c noise
KT/C noise exsits in sc circuits, that is, when sampling a signal, the random thermal noise (KT/C noise) is also sampled to the sampling capacitor, so in different clock cycles, the sampling value for the same input signal should be different also. is that right?
but when circuit simulation, the value is almost the same.why?
someone says that, for some library, thermal noise model of MOS transistors is not included, that is, KT/C noise doesn't exist in circuit simulation, is that right or not? why ?
and how to find whether thermal noise model of MOS transistors is contained in the library?
for an ADC,if the simulated ENOB=9.7 or worse(for 10 bit resolution), then is KT/C noise included or not?
pls help me, i'm terribly confused.
thans all for reply.
