yuguo
Hi, I am a beginner in analog design, and I am trying to build a folded-cascode opamp,
While I found in the simulation results that the linearity is poor, there is 10% difference of the gain between the maximum input and input ten times lower.
Is there any suggestion on how to improve?
I have checked the biasing, seems there is no problem.
Another question is that, how to calculate DC gain?
I am using spectre, is it ok if I load the circuit with an infinite resistor?
P.S. The supply voltage is 1.1V and output swing is 0.5Vp-p, with four transistors cascoded.
Thank you very much for your help in advance
