About Dsign Cmpile timing report
kjtom
Newbie level 5
Newbie level 5
Dear all,
I met a confused DC timing log.
The slack calculation resault is very confused.
I list it as followed,
Report : constraint
-all_violators
-verbose
Design : SPI_CTRL
Version: 2003.06-2
Date : Fri Sep 22 13:52:57 2006
Startpoint: MODE_SEL (input port)
Endpoint: ADC_SEL_tmp_reg
(rising edge-triggered flip-flop clocked by DCLK')
Path Group: DCLK
Path Type: min
Des/Clust/Port Wire Load Model Library
SPI_CTRL WL1K comnlsc06v10
Point Incr Path
clock (input port clock) (rise edge) 0.00 0.00
clock network delay (ideal) 0.00 0.00
input external delay 0.00 0.00 f
MODE_SEL (in) 0.00 0.00 f
U174/Z (OR02D1) 0.30 0.30 f
U98/Z (ORA21D1) 0.50 0.79 f
U172/Z (MX02D2) 0.55 1.34 f
ADC_SEL_tmp_reg/D (DFCRB1) 0.00 1.34 f
data arrival time 1.34
clock DCLK' (rise edge) 250.00 250.00
clock network delay (ideal) 0.00 250.00
ADC_SEL_tmp_reg/CP (DFCRB1) 0.00 250.00 r
library hold time 0.07 250.07
data required time 250.07
data arrival time -1.34
slack (VIOLATED) -248.73
The definition of slack is "data required time - data arrival time".
Why the slack is -248.73? It should be 248.73!
Can anyone explan this case?
Hi ,
I am more like a FE so please correct me if i am wrong .
YOu are doing a Hold check
so slack = - ( data required - data arrival)
Few observations in the report .
1) No External delays for I/P port
Do you define this as a Multicylce path ?
I am seeing Hold check after 1cycle , this is reported only if you declare this as a MCP other wise data required should start from 0.0 ?
please change your constraints if you declare this as a MCP ?
If so you have positive slack of 1.27
Thanks & Regards
Y . Laxmi Narayana
kjtom said:
Dear all,
Report : constraint
-all_violators
-verbose
Design : SPI_CTRL
Version: 2003.06-2
Path Group: DCLK
Path Type: min
Point Incr Path
    kjtom
HI,
Check u r clock period...whats u r time unit?
beacuse u r data arrival time is around "1.34"....and u r clock cannot be "250.07"...usually u can add some buffers in the place and route to remove u r slack but i think u have specified u r clock period in the wrong manner....check the time unit used in u r technology library?
Regards,
dcreddy
    kjtom
