kannan2590
Member level 4
![Member level 4](/styles/images/ranks/dlevel4.gif)
the code for fir filter is
when i synthesize this code i get warning messages like <dout 1>,<dout 2>,<dout 3>,<dout 4>,<dout 5>,<dout 25>,<dout 26>,are unconnected.so i am using vertex 4 fpga and the simulation results are coming correct inspite of these warning messages . whether these warning messages effect the output in fpga and if it effects how to correct and solve such warning messages?
Code VHDL - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 library IEEE; use IEEE.STD_LOGIC_1164.ALL; use IEEE.STD_LOGIC_ARITH.ALL; use IEEE.STD_LOGIC_SIGNED.ALL; ---- Uncomment the following library declaration if instantiating ---- any Xilinx primitives in this code. --library UNISIM; --use UNISIM.VComponents.all; entity subfilt1 is Port ( dout : out STD_LOGIC_vector(27 downto 0); clk : in STD_LOGIC; reset : in STD_LOGIC; din : in STD_LOGIC_vector(7 downto 0)); end subfilt1; architecture Behavioral of subfilt1 is component DFF is port( q : out STD_LOGIC_vector(7 downto 0); --output connected to the adder Clk :in std_logic; -- Clock input rst :in std_logic; d :in STD_LOGIC_vector(7 downto 0) -- Data input from the MCM block. ); end component; signal H01,H049 : STD_LOGIC_vector(19 downto 0) := (others => '0'); signal MCM02,MCM03 : STD_LOGIC_vector(27 downto 0) := (others => '0'); signal add_out02 : STD_LOGIC_vector(27 downto 0) := (others => '0'); signal Q02 : STD_LOGIC_vector(27 downto 0) := (others => '0'); signal din1:std_logic_vector(7 downto 0):=(others =>'0'); begin H01 <= "11111111111111110101"; H049 <= "00000010100101011100"; --dff2 : DFF port map(Q02,Clk,MCM02); dff2 : DFF port map(q => din1,Clk=>clk,rst => reset,d => din); p01001:process(Clk,reset) begin if reset='0' then dout <="0000000000000000000000000000"; elsif clk'event and clk='1' then MCM02 <= din*H01; MCM03 <= din1*H049; add_out02 <= MCM02+ MCM03; dout <= add_out02; end if; end process p01001; end Behavioral;
