about comparator simulation(Ioh,Vol)
holddreams
Full Member level 6
Full Member level 6
Shanghai
https://www.st.com/stonline/products/literature/ds/4065.pdf
The above is a comparator datasheet.
I have some questions:
1.on page 3, There are two parameters:IOH,VOL,
Anyone can tell me how to simulation these two parameters?
And why not VOH,VOL? or why not IOH,IOL?
2.for a camparator circuit,phase margin is necessary or not?I think phase margin only in feedback circuit.
Thanks.
Apply input voltage difference between true and complement of +1V and apply 3V at output. Then measure current sink inside the circuit. This will give IOH
Similarly apply negative input voltage and supply a 6mA current to the output pin, and measure the voltage on output node. This will give VOL.
From application diagram this is only nmos driven and you cannot drive a high voltage from this circuit. So VOH cannot be defined here. But IOL can be defined for this circuit for a particular voltage driven at the output.
