nikhillife11
Member level 2
Hello friends
Now if i charge a cap to its peak and then remove the supply and connect it back to load. It will pass the voltage to the load while linearly dropping the voltage across it. But the question is Does this voltage make a current to flow through the load? If yes how can we calculate this current.
Thanks and Regards
Nikhil
Thanks and Regards
Nikhil
