a transistor at high frequency
hp.jupiter.3d
Newbie level 1
Newbie level 1
hello
I need a transistor at high frequency,that works in f= 500 MHz
thanks
There are many transistors usable at 500 MHz. But you should indicate the purpose of the device you want to build with it. Different transistors are used in low-noise amplifiers, and different to generate a high power, e.g. >0.1 W.
