hiphei
Junior Member level 1
I don't know why i started thinking this in the first place, but eventually it has started bothering me more and more because i haven't been able to confirm this from any book i have my self or find the proper answer even with google..
If there is basic textbook boost converter circuit (input cap, inductor, switch, and freewheeling diode going out from their junction to output cap).. The switch is most often mosfet and they have body diodes.. Is there a real principal function (can one say like that?) with a body diode in such a circuit..? If i think how it works, i can see no function with it except being in non conductional state when required..thus having some junctional charge and contributing to some switching losses..
Even though the circuit resembles crt television line output stage a lot, it still functions very differently; in line output the switch, which is typically bjt, has parallel flyback diode oriented like the body diode in boost converter..collector is connected to transformer primary and also to load which is deflection coil and resonating cap..while the beam sweep, the energy is 'charged' to primary circuit magnetics, but during the beam flyback the switch opens, and the resonating 'flyback' capacitor sets in and gets the beam quickly back (during a half of cycle)..but since current and voltage lag each other, the diode is needed for the 1/4 of the cycle..or half of the flyback..for the deflection current to run that way..
But i can not see any such functional duty for the switch body diode even though some parasitic currents can flow there..
But somehow my brain haunts me that there may be something else going on there..i just can't find it out or conclude it out.. Any real knowledge out there?
