But I think the emitter area of the BJT at the output stage is A and not 12 A.
ronsmithy said:A little analysis on this circuit for you.
r23718 said:In case you will be running sims be aware that this circuit does not have any startup - will run ok in sims but probably will not be as good in silicon.
Add any of the Razavi;s startups and you will be fine.
