A simple question about ring oscillator but trouble me
incol
Full Member level 2
Full Member level 2
Razavi's book said that if the gain of the delay cell (fig 1) is low, the ring oscillator can't oscillate, the gain A=[µ0(W/L0) / µ2(W/L2)]½, so we should increase W/L0 to let it oscillate, but I find that if I increase the bias current, it can also oscillate. The gain of the delay cell doesn't increase, how can it oscillate?:cry:
anyone can help me?:cry:
what the gain is of this figure?
It is bigger than 1.
the gain of the delay cell is A=[µ0(W/L0) / µ2(W/L2)]½, yes, it is bigger than 1, otherwise it can't oscillate. But I din't know why I increase the bias current, it can also oscillate, the gain didn't increase at this time.
add a initial condition and try.
such as the initial voltage of out1 is "high" while out 2 is "low"
I had already add a initial voltage in out1. I want to know why I increase the bias current, it oscillates, the gain didn't increase at this time.
i dont think the Gain formula is accurate, if you in crease the biase current, usually the gm is creased and hence increase the gain.
in fact, increase the current the gain increase too.
do you consider the rds of M2 and M3?
yes, thank you!
another question: when I run the corner simulation, I found the gain is too small in mos_fs, and in mos_ss, M5 will go into linear, because vcc is only 2.7v. I think this delay cell cann't meet my request, so could anybody introduce a better delay cell to me? thanks!
m5 go into linear will not affect more performance.
and increase w/l of m1 to m3 maybe help
but the simulation result told me that when vcc=2.7v, the bias current decreased very much, and frequency decreased, when vcc=5.5v, it worked well. I think this is because M5 came into linear when vcc=2.7v.
why not increase the W/L of all the cmos?
it seem that the Vds too big for all cmos.
and you can use current source load for it.
if I increase the W/L of all the cmos, the parasitic capacitor will increase, and the frequency will decrease, so I have to increase the bias current, I think this is no useful.
and what do you mean current source load for it?
If M2 and M3 have independant gate bias voltage, they are current source load. Two minimum inverter in series can also be a delay cell.
how much is the gate bias voltage, I had used a 1.22v gate bias voltage, but the output waveform is not good. This structure is better than diode connected?
and about two minimum inverter in series, I think differential structure is better than single structure.
For diode connected transistor, Vds=Vth+Vd,sat
For the current source load, Vds=Vd,sat
Added after 1 minutes:
You said you need differential structure delay cell, then I think Maneatis can help you :)
is this delay cell usefull?
M7 is a current source, M6 is source follower, so Vout1=Vds of M2.
