hebu said:If the Vin=5V, and LDO out=1V.
In addition, the LDO out curent=500mA. Does it mean the current into
the regulator is 100mA?
Thanks,
scottieman said:hebu said:If the Vin=5V, and LDO out=1V.
Thanks,
Lets see do I interpret your question correctly. When there is 500mA of current flow out from the LDO at Vout = 1V, I guess the current flowing into the LDO at the Vin pin will be 500mA too. Therefore, the power efficiency of LDO is:
Efficiency = Pout/Pin ~ 1.0V x 0.5A / 5.0V x 0.5A = 20%
That is a proof that LDO is relative lossy comparing with switching power converter. Moreover, that is also why people would like to reduce the dropout voltage (e.g. different between Vin and Vout for minmiizing power loss).
Hope this help
Scottie
suria3 said:500mA is the current provided to the load of the LDO, but the total power consumed by the load of LDO will be VDD * 500mA.
hebu said:1) The meaning of "Low dropout" is the difference between Vin and Vout?
or the source resistance of voltage source is small despite the loading
sinks large current suddenly?
Anybody can tell me what's the correct definition of "LDO"?
hebu said:2) Why the efficinecy is so bad such as 20%?
hebu said:3) Often, what's the efficiency of LDO? For example, 3V to 1V.
hebu said:I can't realize why the current into LDO is such high as 500mA?
Is it a typical case?
Thanks,
eda4you said:However, the example with 5V in, 1V out --> so the series transistor has a Vds of 4V, 500mA output --> 2W are dissipated by the ldo, the output power is 500mW and 2.5W have to be delivered by the 5V supply. So you will get an efficency of 0.5W/2.5W = 20%. But the input current is approximately also 100mA and not 500mA!!!
scottieman said:eda4you said:However, the example with 5V in, 1V out --> so the series transistor has a Vds of 4V, 500mA output --> 2W are dissipated by the ldo, the output power is 500mW and 2.5W have to be delivered by the 5V supply. So you will get an efficency of 0.5W/2.5W = 20%. But the input current is approximately also 100mA and not 500mA!!!
Just wonder it is typo or not:
"But the input current is approximately also 100mA and not 500mA!!!"
From my understanding, the input current should be 500mA, since Pin = 2.5W and Vin = 5V.
Scottie
hebu said:By the way, why we need LDO regulator rahter than connecting
the battery to the functional circuit directly
