A simple doubt in C !
truebs
Full Member level 5
Full Member level 5
Asia
We all know that for x=2
y = ++x ; y becomes 3
y = x++ ; y becomes 2 and x becomes 3 in both cases.
But as per rule of precendance... ++ operator has higher priority than = operator.
Then as per precendance .. y should become 3 in both the cases owing to higher precendance to ++ than =.
But it doesn't happen , why ? What is the possible bug or behavior of compiler ?
Thanks ..
"y = x++" means increment x after evaluating the expression.
So in this case, the expression is evaluated while x still equals 2, thus setting y to 2, and then after that evaluation is finished, x is incremented.
That's correct. Order of execution and precedence are two different, independent things.
I totally agree with lambtron and echo47, ++X and X++ are two different things.
Maybe if your code was:
++X;
X++;
Then there won’t be much difference but since you added an “=” to the expiration they will have two different effects.
hi,
in this statement:
x = *buf++;
means that x equals to *buf but for the next case buf points to next adress in memory.
if you write;
x = *(buf++);
x equals to the value in adress (buf+1),
that is the trick!
