A "separated double pole switch with a single throw" ( two separate switched ccts)
T
treez
Newbie level 1
Hi
Is there any such thing as a rocker switch which switchs two circuits from the one actuator? (whats it called?)
(ie we want to switch a circuit with several amps in it, but also want an indication that the switch has been thrown with a smaller contact in the switch which we will engage in a signal circuit where a microcontroller will be signalled that the switch has just been thrown.)
Re: A "separated double pole switch with a single throw" ( two separate switched cct
I have seen multiple switches mechanically ganged
but they all seemed to be "customized" by the
integrator of the assembly.
You might consider a small relay instead, that is
powered off the switched circuit. This might have
the added benefit that it declares result (power
present) rather than intention (switch position).
Reactions: treez
    T
Obviously an DPST switch...
Or did I misunderstand something?
Klaus
Reactions: d123
    d123
Thanks, i mean like a DPST but the poles not serving the same circuit
You are free to wire the two poles as you like...as long as you satisfy safety regulations.
Klaus
