A question in HFSS 10, can any one help ?
Goher
Junior Member level 2
Egypt
Dear All,
First of all, i wish you all luck and happiness in the new year.
Now, I'm working on HFSS 10 and i need to know if their any ability to export the plotted Field inside any cavity in terms of V/m to an external file ??
I need to get the field values that HFSS simulated in order to do some further process and write a Matlab code that defines the Field/Particle interaction inside a magnetron cavity.
Thank you so much
Best regards,
Goher
m_goher(at)yahoo.com
i have a idea:
set a plane(2D) inside the cavity and then you can get the field on this plane.
quote from hfss help:
A plane object is a cutplane through the problem region. You can plot fields or perform field computations on its surface. Planes are always considered non-model objects by HFSS
I don't think you would be able to export field data as a volume matrix.
People from ansoft are very keen not to let costumers use non-ansoft postprocessing tools.
:cry:
    Goher
