A question about Schockley's Diode Equation
alfred_duj
Newbie level 1
Newbie level 1
Can anyone help me what is the difference between:
Id=Is(e^(kV/Tk)-1)
and
Id=Is(e^(vd/nVt)-1)?
Thank you!
hi,
I = Is( exp(Vd/nVT) - 1) ---------------eq.1
where
I is the diode current,
IS is a scale factor called the saturation current,
VD is the voltage across the diode,
VT is the thermal voltage,
and n is the emission coefficient, also known as the ideality factor. The emission coefficient n varies from about 1 to 2 depending on the fabrication process and semiconductor material and in many cases is assumed to be approximately equal to 1 (thus the notation n is omitted).
The thermal voltage VT is approximately 25.85 mV at 300 K, a temperature close to “room temperature” commonly used in device simulation software. At any temperature it is a known constant defined by:
VT = kT/q
where
q is the magnitude of charge on an electron (the elementary charge),
k is Boltzmann’s constant,
T is the absolute temperature of the p-n junction in kelvins
If we substitue VT (called " volt equivalent temperature") value in eq.1, u will get another equation.
if u think this info. is helpful, please click on helped me button.[/i]
    alfred_duj
