a question about parellel capacitor
will_fung
Junior Member level 1
Hi Everyone,
I have a quesion about parellel-capacitor, if I need 2200uF on the trace, what if I place 10 pcs of 220uF cap instead of one 2200uF?
You know, every cap has ESL and ESR, if I place 10 pcs of cap parelleled instead of one 2200uF cap, the ESL and ESR should get much smaller, and it should perform better. Am I right?
Besides, if I place 10 pcs of cap instead of one 2200uF cap, is there some bad effect except a big space needed?
Thank you.
If you are dividing total capacitor value equally it will not create a problem. 2200µF capacitor can be divided into 220µF * 10, but if you are mixing different values of capacitors may create ringing effect or distortion.
HI ,
you mean that if I divide a capacitor into several different value of capacitors, it would cause some problem? such as a 330uF capacitor, divide into 220uF+100uF+10uF, it would create ringing effect or distortion. right?
could you explain more detailed about the ringing and distortion? If the capcitor is used on power trace, is it still create this kind of problem?
Thank you.
Every capacitor has a parasitic inductor & series equivalent resistor (Look at the equivalent diagram of a capacitor). Every different value of capacitors are having different ESR & ESL. Even the same value capacitors also has different ESL & ESR value depend on the specification & manufacturer. So the self resonating frequency of the capacitor also vary with respect to the ESR & ESL. So the different self resonating frequency will create noise in the power supply. Even different lead length of the capacitor also create the noise due to the variation in inductance.
If the application area is more sensitive then care must be taken in PCB design itself.
Single capacitor(or same value capacitors in parallel) also will give noise due to self resonance but all the noise waveform will be in synchronous. To avoid this problem we must use a serial inductor, T tilter or Pi filter
www.ultracad.com/articles/esrbcap.pdf‎
Regards
Udhay
you can do it like that ,but you'd better place them together ,if not ,may be introduce some resonance problems.
