incol
Full Member level 2
If I design a ring oscillator that is independent of power supply and temperature, is it that only I can choose the bandgap reference in my circuit? is there another method?
thanks!! [/code]
thanks!! [/code]
rfsystem said:If you choose a LC as frequency determine there is no first order dependence on supply.
A tricky idea is if you being forced to use a ringoscillator to use the supply as a VCO regulation input. So the supply is then of minor importance.
