A question about Charge pump
holddreams
Full Member level 6
Full Member level 6
Shanghai
In the attachment,
For transistor MD2 and MS2,
1)which node is the source?
2)How to connect the substrate of MD2 and MS2?
Thanks.
Any. MOS transistor has symmetric structure.
All of them NMOS transistors. Substrate is connected to the ground.
    holddreams
Thank you.I got it.
If we use PMOS instead of Nmos,How to connect the Pmos substrate ?Using floating Nwell?
Any idea?
holddreams said:
Thank you.I got it.
Any idea?
As far as I known, there are at least 3 solutions:
1. Floating well, as you mentioned.
2. Dynamic substrate connection switching: At least 2 methods. Please refer to
a. Pierre Favrat..et al, "A High-Efficiency CMOS Voltage Doubler", JSSC V-33, No.3, Mar. 1998, p410~.
b. Jongshin Shin..et al, "A New Charge Pump Without Degradation in Threshold Voltage Due to Body Effect", JSSC V-35, No.8, Aug. 2000, p.1227~.
3. Tie to highest voltage: Please refer to
B. Robert Gregoire, "A Compact Switched-Capacitor Regulated Charge Pump Power Supply", JSSC V-41, No.8, Aug. 2006, p1944~.
