devilliers
Newbie level 3
Hello, I was advised to seek information here regarding a Project I plan.
I am wanting to put together a simple PWModulator.
The Input would be a Pulsed Wave of varying widths.
The first requirement is to then apply a correction to this input by way of extending the widths by up to 40%.
There should be a pre-set variable resistor that is capable of changing the degree of variation. At no point is there to be a need to reduce the widths below that of the input.
Secondly, there is a requirement with another pre-set variable resistor to set the Threshold at which the variations are commenced. The commencement point over which modulation should begin would be limited to around the lowest 20% of the input signal widths.
Should anyone have any interesting suggestions as to how to set about the project I would be very interested to hear from them...
