naxingyu
Newbie
We discovered a problem when building an inventor from DC to AC. When the IGBT module was working at 15kw and the voltage of the DC power supply was 650V to 700V, the 5V and 3.3V power supply for the control chips fluctuated significantly, causing the chip to restart. We suspected that it might be caused by electromagnetic interference. We tried grounding, adding filters, and other measures but it didn't work. What is the possible cause and how to solve this problem?
