7rots51
- Joined
- May 17, 2002
- Messages
- 1,183
- Helped
- 25
- Reputation
- 50
- Reaction score
- 12
- Trophy points
- 1,318
- Activity points
- 9,636
hdlc_transmit
Hello
I have a problem with keil in this project ,please read this code and find the problem,my guess is that code optimization levels may produce the bug.
Open this project in keil 7.06:
State 1:
compile it with this options: AT89C52(use extended linker and assembler LX51 AX51),code optimization in level 8,remove tick of linker code packing.
go to debug mode and open disassembly window and c:0x0142 you can see that MT9092_Rd returns byte in R7 and the main program use it as status varible.
there is no problem and everything goes well.
exit debug mode.
State 2:
compile it with this options: AT89C52(use extended linker and assembler LX51 AX51),add tick of linker code packing,code optimization in level 11.
go to debug mode and open disassembly window and c:0x006A you can see that MT9092_Rd returns byte in R7 and the main program doe not use it as status varible.the return value of MT9092_Rd function in R7 (status variable in main
function) does not used and missed!
This is my problem,please help me to solve it.
Only this part of code is under verify:
at main fuction,return value of HDLC_Status_R() as status variable.
while(1)
status = HDLC_Status_R();
status = status >> 2;
status = status & 0x03;
if(status == TxEMPTY)
TXX = 0;
HDLC_Transmit();
State 1 disaasembly:
34: while(1)
35: {
36: status = HDLC_Status_R();
C:0x0136 7F04 MOV R7,#0x04
C:0x0138 120159 LCALL MT9092_Rd(C:0159)
37: status = status >> 2;
C:0x013B EF MOV A,R7
C:0x013C 13 RRC A
C:0x013D 13 RRC A
C:0x013E 543F ANL A,#0x3F
C:0x0140 FF MOV R7,A
38: status = status & 0x03;
C:0x0141 530703 ANL 0x07,#0x03
39: if(status == TxEMPTY)
C:0x0144 BF020E CJNE R7,#0x02,C:0155
40: {
41: TXX = 0;
C:0x0147 C2B4 CLR T0(0xB0.4)
42: HDLC_Transmit();
C:0x0149 1201D9 LCALL HDLC_Transmit(C:01D9)
State 2 disaasembly:
34: while(1)
35: {
C:0x006A 3188 ACALL C:0188
C:0x006C 13 RRC A
C:0x006D 13 RRC A
C:0x006E 543F ANL A,#0x3F
C:0x0070 FF MOV R7,A
C:0x0071 530703 ANL 0x07,#0x03
C:0x0074 BF020D CJNE R7,#0x02,C:0084
40: {
41: TXX = 0;
C:0x0077 C2B4 CLR T0(0xB0.4)
C:0x0079 31AC ACALL HDLC_Transmit(C:01AC)
Bye
Hello
State 1:
exit debug mode.
State 2:
while(1)
TXX = 0;
HDLC_Transmit();
34: while(1)
35: {
C:0x013C 13 RRC A
C:0x013D 13 RRC A
40: {
41: TXX = 0;
34: while(1)
35: {
C:0x006C 13 RRC A
C:0x006D 13 RRC A
40: {
41: TXX = 0;
Bye
