A problem about set up model library in cadence
lijianheng
Full Member level 2
Full Member level 2
load model library automatically in cadence
When I set up model library using cadence analog artist, I found there is some model lib files listing in the panel automatic, but not all. What should I do if I want to change those automatic listing files just by once operation, and don't need to change the library files everytime when i setup a new design.
Thanks
You can load this list from previous design.
    lijianheng
Thank you, Fom
But I can't find how to save the model library files.
To save :
Session -> Save
To load :
Session -> Load
In a pop-up menu box you can select previous design that used the same model like new one. Also you can select what items you want to be loaded. In your case only models.
It does work. Thank you for your advice.
