tiger_ads
Member level 3
lna output matching
i have read the topic "lna &mixer test design in receiver" ,I understand a lot, but still have some confuse.
i am going to design a lna and a mixer individually on the same chip,so dont i need a buffer??
i want to know the details about output matching of lna, as i have read, the output is high Q node, so it is hard to match it on chip, this meaning is matching is on board?? when simulationg, use ideal passitive component is for this reason??
and what simulation result should i concern about when output matching?? only S22??
my lna is single end with two stage, one is cascode, the other is common source for improving gain. what should i do for output matching???
thanks a lot !!
thanks a lot !!
