lean
Junior Member level 1
feedback techniques
Hello everybody. I would like ask you for a curious phenomemnon by
measuring
the output impedance in a circuit. Take a look to this
(www.eurobotics.org/vco/circuito.doc) simple circuit. When I meassure
the
output impedance using the convencional way, that is, using a voltage
source
at the output while shortcutting the dependences ones I get 6 MOhmns. If
instead of this I use feedback techniques to calculate the output
impedance I
get 30 GOhmns... What is going on?.
Thank you all.
measuring
the
source
impedance I
Thank you all.
