A pair of ICs , that does AES/EBU <-> I2S conversion?
spktu
Member level 5
Member level 5
aes/ebu ics
Please advise a pair of ICs , that does AES/EBU <-> I2S conversion.
i2s aes/ebu
Look for Crystal (Cirrus Logic) and AKM components
Look for an AES/EBU/SPDIF Receiver and Transimitter
SPDIF is the consumer version of the AES/EBU.
regards
Yelloww
aes/ebu i2s
What is not included in SPDIF, that makes it the consumer version of the AES/EBU?
aes i2s
hmm, AES/EBU have 2 modes, professional and consumer, but consumer AES-EBU isnt really the same than SPDIF (check this pdf for example **broken link removed** ). Also the diference between AES/EBU and AES3-2003 (check aes web to get a courtesy copy) its just the transformers.
as pointed yellow, with just one cirrus 8420 you have already everything https://www.cirrus.com/en/products/pro/techs/T4.html , check the datasheet, you can have both working at same time:
in I2S-out AES3
in AES3-resample if needed-out I2S
