strongdrink
Junior Member level 2
Hello all,
I recently bought a couple of LM311N comparators.. only trouble is, I am a bit confused on what everything does.
To my knowledge...
pin 2 gets compared with pin 3
if pin 3 has a greater voltage pin 2, it will send the voltage of pin 2 to the output pin (7)
from pin 7, you can hook up an LED or something
I am not sure what the "balance" or the "balance strobe" pins do
Do I connect the Vcc and Ground, or Vcc and Vee?
Thanks for any help
To my knowledge...
Thanks for any help
