tajiknomi
Member level 4
A little problem is designing Power Backup System
I am trying to design a circuit for my router to be ON 24/7 without interruption. The place where I am living right now has some electric power issues so i want to power my router from batteries (if the main power isn't available for sometime).
Here is how I want my system to work.
When MAIN power is available, use it to power router and charge the batteries IF PD of batteries is below some threshold value. If MAIN power isn't available, use batteries to operate router.
For that purpose I have design a simple circuit , here is a rough sketch of it.
The RELAY is used to switch power b/w battery and Main supply. Comparitor (OP-AMP probably) will be used to sense the threshold value of battery, if it is below the specified value (selected by R1 and R2 divider), MOSFET will be ON to charge batteries otherwise it will be off.
I am stuck at position A (in the above screenshot). Suppose batteries are charging , then at position A the potential supplied through the mosfet will be 12V(to charge batteries) but that potential will also be seen by position B which is connected to the Comparitor and it will be turn off the mosfet and the result would be the ON/OFF loop of mosfet. How to handle this scenerio ?
Any help would be appreciated.
