julian403
Full Member level 5
If we take a look what's a frame relay is we can resume that's a 1 and 2 layer's protocol. It was made to fix the transport's data trouble in an ISDN network.
https://en.wikipedia.org/wiki/Frame_Relay
But there is what it's call virtual circuits
That's a layer 3? Because the protocol specify differents path switching. What I'm missing?
Regards.
Frame Relay is a standardized wide area network technology that specifies the physical and data link layers of digital telecommunications channels using a packet switching methodology. Originally designed for transport across Integrated Services Digital Network (ISDN) infrastructure, it may be used today in the context of many other network interfaces.
As a WAN protocol, Frame Relay is most commonly implemented at Layer 2 (data link layer) of the Open Systems Interconnection (OSI) seven layer model. Two types of circuits exist: permanent virtual circuits (PVCs) which are used to form logical end-to-end links mapped over a physical network, and switched virtual circuits (SVCs). The latter are analogous to the circuit-switching concepts of the public switched telephone network (PSTN), the global phone network.
Regards.
