A dummy question about op-amp
gusts
Junior Member level 2
Latvia, Riga, Baldone
A dummy question about op-amps
Hello all!
I just wanted to ask a very simple question. I know very basics about op-amps - input impedance high, output impedance low, output can never exceed saturation limits etc.
Question - can op-amp output both sink and source current? I know when a pin of a microcontroller port is an output pin it can sink and source current. Is it the same in the case of an op-amp?
Sorry for the question! I hope you understand me.
gusts
Re: A dummy question about op-amps
Yes, an Opamp pin can act as both Source and sink. Here is tutorial from MAXIM
Hope this is helpful
Reactions: gusts
    gusts
Yes however the actual output voltage may vary. Some go from V- to V+ -1.5V, and some V- to V+ so look at the data sheets closely.
