a dc to dc converter problem
wei9321
Member level 3
Member level 3
when the converter no load,
it's output voltage can not steady
but afther adding the mini load
the output voltage is stable
and the temperature rise,
the ouout voltage rise fast
why?
Could you write some others details about the converter e.g. topology (Buck, Boost, ...), feedback type (voltage mode, current mode, ...), functioning mode (CCM, DCM, ...), voltage on input/output and so on...
Do you've some circuit schematic?
Bye
no_load can be problematic, but it neednt be............
some of the old power ICs couldnt deal with it cuzz they always came on every cycle
but newer ones do skip cycle etc etc and can handle it easy
im surprised yo are having this problem
Bye
topology:flyback
feedback type:current mode
functioning mode:CCM
input:18-75v
output:5v/2A
Do you've also a schematic?
Bye
