jjww
Newbie level 1
crystal circuit design
One pin 455K OSC resonance circuit:
circuit description:
this circuit used to generate a 455KHz clock signal from 2v to 5v, the crystal one pin connects to the osc pin,the other pin connects to GND.when the output of I128 changes from one to zero, this circuit starts to oscillate a 455KHz clock signal, while it changes from zero to one, the circuit stop oscillating.
question:
when 2v=<VDD<3.6v, this circuit generate a frequency of 455KHz, which is the parallel resonance of the crystal that connected to the OSC pin; but when VDD increases higher than 3.6v, this circuit generates a frequency of 6MHz, what is the reason of this phenomena, and how can I adjust the parameter of this circuit to make the circuit always generates a 455KHz signal from 2v to 5v, the relation between the frequency of the internal RC circuit,which constructured by I130、I38、M9、R5、R6、R7 and the frequency of the external crystal should be what? I expect some kind-hearted friends to help me.
question:
