It is a copy of well known amplifier with one speaker, power of 40W and two modes: drive and more drive. Schematic and the board were drawn in PROTEL. It is a copy of the original board.
Most of elements like mains and speaker transformer, choke and chassis were made to order.
List of elements:
- speaker
- transformers
- choke
- tubes
- angles
- handle
- artificial leather
- front panel
- inscriptions
- bases
- switches
The box was made of 18mm thick OSB plates. Lipping was milled. Plates were then screwed and glued. The whole housing was finished using a universal spatula and later with orbital sander. Before covering the housing with artificial leather, it is recommended to make a model of glued newspapers. Design of the front was made in Corel. Speaker – Eminence Legend 1258 (75W, 8ohm, 12 inches). Tubes used in preamplifier and inverter – 12AX7 from Sovtek. On the power amplifier it is 6L6WXT+ (also Sovtek). There is also a reverb spring removed from an old Eltron 60.
Link to original thread - Kopia wzmacniacza Fender Hot Rod Deluxe
