Again, a regulated voltage supply and LEDs in parallel. Not the best way to do it. Also note that the LEDs used in that project were salvaged from an existing lamp where it is likely they were selected for matched Vf. If you get them from another source the chances are you will cook some while others don't get beyond a dim glow.
