rokor
How far RF signal (2.4 GHz, 802.15.4 standard) can travel between containers? Average cargo container size: Width 8 feet (2.5 M), Height 8.5 feet (2.6 M), Length 20 feet (6 M) or 40 feet (12 M). Containers may be stacked up to 6 levels vertically, up to 12 rows wide and 15 rows long. The horizontal gap between containers is about 2 inches (5 cm), same distance minimum between the walls (vertical gap). A good picture of cargo ship is here: **broken link removed**
Low profile (dipole) antenna will be placed on the top of container, close (about 20 cm) to the corner, about 2 cm from container surface. What minimum transmitter power we may need to support container-to-container communication, if our “smart” containers may be 5-8 containers away of each other in any direction? These containers should be able to create a network, to relay their ID’s to the control point, or to “main” container, which becomes a (low speed) communication hub for all “smart” containers.
I don’t have RF simulation tools, so any ideas what can be used (frequency, power, polarization etc.), will be greatly appreciated.
