Robertt
Junior Member level 3
I installed IC5033 in RH9. I can start up the cadence tool by icfb.
I also can entry the schematic. But when I try to simulate it in Analog Environment, it doesn't work.
When I add model library in the Analog Environment, I click the Browse button, but in the poped window, I cannot double click to choose a directory or a file. I have to type the directory for the model into the blank and click "Add" button to add the model.
After done this, I click "Run". But it failed run the simulation. it even doesn't generate the netlist.
what's wrong with the cadence? Is the problem that I didn't correctly install it?
